Add Images to Controls
It is possible to add images to the following controls in Process Studio:
- Button
- File browser
- Label
When a new template is created, an images and a modules folder are created in the same folder where the template file is created. For example, the folder structure below would be created when creating template sample.pmt in the sampleTemplates folder:
