Framework
The IHWMFramework Interface
If the IHWMControl interface is implemented, an instance of the IHWMFrameWork interface will be passed on to the bean. This is the point where beans gain access to various classes (as interfaces) in the Process Manager architecture, including:
Class | Description |
DataModel | Place holder for bean to share data, you can store process data. |
Workflow | The Workflow Manager serves as a handle to the workflow. |
Communication Manager | This interface is the gateway to spawning third party applications and establishing a socket connection with them. |
Menu/Tool bar Customizer | Many applications will require you to add new items to the menu bar or toolbar, both of which can be modified in the designer mode. |
Other important APIs provided by the IHWMFrameWork interface include:
API | Description |
GetTemplateDir/GetTemplateFileName | Get the directory/filename of the current process definition file. |
GetProjectDir/GetProjectFileName | Get the directory/filename of the current project instance file. |
LogStatus | Display the given message in the status bar of the application. |
AddHWMEventListener | Beans can use this function to add themselves as listeners to events, such as File Save. |
