GUI Design
Available Controls
- Database controls
- HyperMesh controls
- Utils controls
- Button
- Allows you to create a button
- Check box
- Allows you to create a checkbox
- Combobox
- Allows you to create a HWM combobox
- File Browser
- Allows you to create a file browser button
- Label
- Allows you to create a label
- ListBox
- Allows you to create a HWM listbox
- Radio Button
- Allows you to create a HWM radio button
- Separator
- Allows you to create a separation
- Slider
- Allows you to create a slider
- Spinner
- Allows you to create a spinner
- Text Area
- Allows you to create a multi-line text area
- Text field
- Allows you to create single-line text field
- HMCollector
- Allows you to select a given entity in HyperMesh and FEP client of HyperWorks Motion framework.
- Start HyperWorks
- Allows you to start HyperMesh and establish a communication channel with it.
- PmgrExec
- Allows you to invoke other executable or any application.
By selecting Start HyperWorks and dragging it into the Control panel, you must fill in the Config File type under the Property View. By clicking on the Config File, an Edit configFile dialog box is displayed. Add your HyperWorks executable path in the dialog box and click Close.
- Start DB Client
- Allows you to start DB Client.
