Page View Panel
You can drag and drop controls from the Process view panel onto the page (Page view) area. Multiple controls can be placed on a single page. New pages can be created by selecting New from the Page menu, or its toolbar equivalent. The properties of the control are displayed in the Property view panel, and every control has an instance name. The Process Manager gives a unique instance name for the controls when they are dropped on a page. However, it is highly recommended that you change the name (perhaps by adding a prefix referencing the name of the process). The red line appearing across the Page view panel represents the height of the panel in HyperWorks.
After a page has been designed, you may choose to export the page so that it may be imported in a different process template. This functionality may be achieved through the corresponding menu items in the Page menu. The Page menu also provides the option to export page as a Tcl module. You may edit the Tcl module and manually hook the modified Tcl module to the appropriate task.
