Set Up Template Preferences
  1. From the menu bar, select Tools > Template Preferences.
  2. In the Template Preferences tab, you can give the process a title (user-friendly name).
  3. In the About Dialog tab, you can specify the text to appear in the about box (as an HTML string).
  4. Save the file by selecting Save from the File menu.
