Set up the simulation model, materials, domains, and boundaries.
Define the simulation domain.
View new features for HyperWorks CFD 2020.
Discover HyperWorks CFD functionality with interactive tutorials.
Define global simulation settings, materials, and any multipliers or parameters.
Use the Material tool to assign materials to solid bodies.
Use the Thin tool to define thin thermal layers on surfaces and assign material properties.
Use the Porous tool and its satellite icons to define Cartesian, cylindrical, and spherical porosity on solid bodies.
Use the Sources tools to specify a collection of body forces (momentum or heat) within solid bodies.
Use the Reference Frame tool to define rotating reference frames on solid bodies or surfaces.
Use the Heat Exchanger tool to specify heat exchanger components for a solid.
Define surface boundary conditions.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define output conditions, run the simulation, and view the results.
