Clean up problematic areas on geometry.
View new features for HyperWorks CFD 2020.
Discover HyperWorks CFD functionality with interactive tutorials.
Convert b-spline models to discrete models then clean up the geometry and mesh.
Review geometric errors in the model's surfaces and solids and fix any defects.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Use the Defeature tool to automatically find, review, and defeature holes and other non-essential features.
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
Use the Validate tool to validate your entire model, review surface and solid checks, and fix any issues.
Set up the simulation model, materials, domains, and boundaries.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define output conditions, run the simulation, and view the results.
