Review geometric errors in the model's surfaces and solids and fix any defects.
View new features for HyperWorks CFD 2020.
Discover HyperWorks CFD functionality with interactive tutorials.
Convert b-spline models to discrete models then clean up the geometry and mesh.
Use the Surface tool to find, review, and fix any geometric errors in the model's surfaces.
Use the Solid tool to find, review, and fix any geometric errors in the model's solids.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
Set up the simulation model, materials, domains, and boundaries.
Define radiation conditions and create emissivity models.
Define direct, derived, and constrained mesh motion.
Generate surface/volume mesh by defining mesh controls, or interactively create and edit 2D surface mesh.
Define output conditions, run the simulation, and view the results.
