Solver-Specific Export Options
Solver-specific options used to determine how FE models are exported.
Nastran and OptiStruct
- Remove āEā from real values
- OptiStruct and Nastran solvers do not require explicitly writing an E to recognize the proper exponent of a real number, and removing the E allows one more digit of precision to be included. For example, -1.12E-7 becomes -1.123-7.
- Round numbers close to zero
- With this option, any real numbers in the model whose absolute value is less than the specified value will be written out as zero. For example, if Zero tolerance = 1.0E-12, it means all real values from -1.0E-12 to 1.0E-12 will be exported as 0.0.
- Organize non-structural mass
- Non-structural mass [NSM1, NSML1] must be referenced in case control for it to be applied in the model.
- Adjust RBE3 0.0 weight factor
- The default behavior in HyperWorks CFD when exporting RBE3 weight factors is to maintain all values defined by you, even if they have a value of 0.0.
- Compress Nodes/Element Sets
- When turned on, all node sets and element sets in the model are exported with the THRU statement.
- Export old contact card
- Export Nastran contact cards in old
format.Restriction: Available when exporting Nastran (MSC) files.
- Export CORD2 and CORD4 in long format
- Exports CORD2/CORD4 in long format to retain the coordinate precision.
- Export Node coordinate in
- The model is exported in free format (comma separated format).
- Convert CORD1 to CORD2
- Exports CORD1 coordinate system as CORD2 coordinate system.
- Remove non exported references
- When exporting a solver deck, references to any includes are always written to the master model even if the include itself is set to "Do Not Export."
