CAD Import Options
CAD readers provide options for processing data during import.
You can access some of these options from the Geometry Import Options dialog, while other options are accessed from a reader's _reader.ini file.
Assembly
Create multiple components for linear members
Create multiple components for each member part.
Create multiple components for stiffeners
Create multiple components for each stiffener (one for each property; that is, if we have flange and web, then two different properties and components are created).
Hierarchy as
Type of hierarchy to generate.
  • Choose Assemblies to generate an assemblies/components based hierarchy.
  • Choose BOM Only to generate an empty part-based hierarchy.
  • Choose Parts to generate a full part-based hierarchy.
Insert name field
Customizes the organization and names of components (NX parts). The naming options are specified using the Format option.
  • Choose <Part Name> to use the string attribute DB_PART_NAME from the part. If that attribute does not exist, the part file name is used.
  • Choose <Part Number> to use the string attribute DB_PART_NUMBER or DB_PART_NO from the part. If that attribute does not exist, the part filename is used.
  • Choose <Category> to create and name components based off of the NX categories associated with the geometry.
  • Choose <RID-PDI> to use the string attribute DB_PART_REV from the part.
  • Choose <Layer> to create and name components based off of the layers of the geometry being imported.
  • Choose <Instance Name> to use the name of the part's instance in an assembly. If the part is the root of an assembly, the part filename is used.
  • Choose <Material Name> to use the name of the material if a material is specified for the geometry being imported. Otherwise, the name of the component is unaltered.
  • Choose <Thickness> to use the thickness value if the geometry being imported is a midsurface with thickness information. Otherwise, the name of the component is unaltered.
  • Choose <UG Body ID> to use the internal numerical ID of each geometric body. This value is unique for each geometric body imported.
  • Choose <UG Tag> to use the internal numerical tag of the part instance. This value is unique for each part instance imported.
Sample component name
This corresponds to the NX Part Browser Assign components by name option; the default value is "default", that is the standard component naming. Name corresponds to the Insert name field option in < > (brackets).
Single part only
Consolidate the hierarchy into a single part.
Split components by
Strategy used to split components, which is dependent on the CAD format. Options include one or more of the following (based on CAD format):
  • Choose Body to generate a body-based component.
  • Choose Layer to generate a layer-based component.
  • Choose Part to generate a part-based component.
  • Choose Category to split components by category.
  • Choose Material to split components by material.
  • Choose Thickness to split components based on component thickness.
  • Choose Custom to enable sub-options.
Topology
Cleanup tolerance
Can be Automatic or Manual.
Create solids
Creates solid entities. If unchecked, reads surfaces but does not create solid entities.
Ensure manifold geometry
Extracts the manifold body from a Parasolid general body that is non-manifold and/or of mixed topological dimensionality. If unchecked, extracts Parasolid general bodies as defined.
Extend surfaces
The imported surfaces are extended to match neighbor surfaces.
Faceplates as surfaces
Import faceplates as surfaces if the surface description is present in the file, otherwise import as curves.
Import type
Create an object based on the structure of the file.
Imprint stiffeners
Stiffener lines are projected onto close surfaces and create corresponding topological modifications to these surfaces
Merge edges
Edges are merged together, when possible, during import as part of the cleanup phase.
Perform connectivity
Import the model and compute connectivity. The surfaces will be connected. If unchecked, import the model without computing connectivity. The surfaces will not be connected. This option speeds up import, but may not be suitable for any other purpose than visualization.
Pillars as surfaces
Import pillars as surfaces if the surface description is present in the file, otherwise import as curves.
Prefer detailed
When multiple representations of an object are available, import the most complex one.
Scale factor
Define the model scaling factor during import.
Split periodic faces
Split periodic surfaces to improve the quality and robustness of the import.
Stiffeners as surfaces
Import stiffeners as surfaces if the surface description is present in the file, otherwise import as curves.
Stiffener/beam/ER systems as
Can be one of the following:
  • Solids - Imports these objects as solid entities.
  • Landing curves - Imports these objects as just the landing curves.
  • Landing curves and midsurfaces - Imports these objects as both landing curves and midsurfaces.
  • Midsurfaces - Imports these objects as midsurfaces.
Stitch across bodies
Stitch surfaces belonging to different components.
Stitch different sheets
Stitching across different sheet bodies belonging to the same part/instance.
Target Units
Target unit system to be adopted for the imported model.
  • Choose a specific unit.
  • Choose CAD units to match the unit system to the CAD file being imported. If the target unit system does not match the CAD file being imported, than the corresponding numbers are modified to account for the unit change.
  • Alternatively, choose Scale Factor to adopt the CAD unit system and scale the entities by the indicated factor.
Tolerance value
The reader considers this tolerance as the object space tolerance used to process the CAD data.
Trim surfaces using
Method for trimming surfaces. Can be:
  • Parametric curves
  • Model curves
  • Preferred representation
Visualization only
Import the model for visualization purposes only. This skips many of the import steps (cleanup, stitching, solid creation, and so on) to provide a faster import. The resulting model may not be suitable for other uses.
Entities
Assign properties to components
Assign properties to the corresponding component (for components that have more than one property, properties are not assigned).
BREP and tessellation
Import B-rep or tessellation, with B-rep given preference. If B-rep is present, tessellation is not imported (default). Choose from the following:
  • BREP or tessellation
  • BREP and tessellation
  • BREP only
  • Tessellation only
Compartments
Import both compartments in the files, and compartments defined by “Faces.” The former by importing the geometry, the latter just by creating a metadata; also reference planes are created, because they can be referenced by compartments.
Coordinate systems
Import CAD coordinate systems as system collectors.
Cutout profiles
Import cutout profiles.
Disable layers
This corresponds to the NX Part browser Disable option in Layer filtering mode. The layers to disable in the import should be listed with the same rules as for the NX Part browser entry.
Enable layers
This corresponds to the NX Part browser Enable option in Layer filtering mode. The layers to enable in the import should be listed with the same rules as for the NX Part browser entry.
FE models
Import FE models.
Filtering
This corresponds to the NX Part browser Layer filtering selection.
Free curves
Import free curves (wireframe entities) into the model.
Free points
Import free points into the model.
Groups as regions
Create region entities corresponding to groups.
Hidden (blanked/no show)
Import entities that are hidden, blanked, or no show.
Hidden ply surfaces
Read hidden ply base surfaces.
Holes
Create holes.
IGES compartments
Import compartments in the files.
Layer filter
Import only the specified layer filters. The string should be in the form of "%filter1%filter2%filter3". The filter names are listed, separated by a character that you choose, and inserted as the first element of the string. The example uses '%' as a separator. You can choose another character as a separator, in case one of the listed attribute names contains '%'. HyperWorks CFD will recognize it as it is the first character of the string. A special value of DEFAULT can be used to indicate the default layer filter.
Midsurfaces
In batch mode, and when @Display= layerfiltering, midsurfaces are imported. In GUI import when Creation type is set to Assemblies, this initializes the corresponding option in the NX Part browser.
Notch profiles
Import notch profiles.
Panel profiles
Create curves along the panel profiles.
Parameters prefix
Only import parameters with this prefix. All others will not be imported.
Plane size factor
A factor > 0 for sizing of infinite planes. The factor is a percentage of the modal size.
Ply contour gap tolerance
Ply contour gap tolerance (default 0.3).
Publications
Create regions from the geometry referenced in publications.
Selected categories
This corresponds to the NX Part browser option Categories; they should be listed as they are written in the command file string: “<name1_length> <name1> <name2_length> <name2>…”, where <name<i>_length> is a number representing the string length of the ith category name.
Skip entities
Specific entity types, or even subtypes (that is entity types with specific form numbers) that should be skipped during import.
Solids
In batch mode, when @Display= layerfiltering, solids are imported. In GUI import when Creation type is set to Assemblies, this initializes the corresponding option in the NX Part browser.
Solver
Select the appropriate solver.
Topological properties
Create reference planes and sketch contours, and attach metadata to the systems that own these properties.
Trim ply surfaces
Trim ply base surfaces during import.
Unbounded curved plates
Import curved plates lacking boundary descriptions.
Metadata
Attributes
Import all generic attributes (global and related to single entities) as metadata.
Body ID
Assign body identifier as metadata.
Color
Read color attributes of geometric entities as metadata with integer values.
Density
Read density value as metadata.
Full name
Generate the full CAD name, as retrieved from the CAD part, as metadata. This consists of assembly name/part name/feature name/entity name.
Layer
Read layer value as metadata.
Legacy hierarchy
Generate metadata with the original CAD hierarchy within the part.
Original ID
Import original CAD entity IDs as metadata.
Plate system attributes
Create physical properties assigned in the XML to plate systems and bracket children as metadata.
PMI
Read PMI data for points. New points are created and PMI attributes are attached as metadata.
Prefix string
The string is prefixed to all metadata names. No prefix is used by default.
Stiffener normals
Attach some metadata with information about normals to stiffener/beam/ER systems.
Tags
Create entity name as metadata.
Unique ID
Create metadata to track the unique CAD ID (default). The same identifier can be obtained for two entities when a single entity is split during import.
User Defined
Options
Use this GUI field to enter additional options not explicitly exposed in the GUI, in the form option1_name=option1_value, option2_name=option2_value, and so on. If an option also exposed in the GUI is mentioned in this field, the value of this field prevails.
Colors
Colors
Read color attributes of geometric entities as metadata with integer values in RGB format.
PDM Attributes
Material name
Name of the CAD attribute containing the PDM material name info of the current part. Default is MATERIAL_NAME.
Mesh flag
Name of the CAD attribute containing the PDM mesh flag name info of the current part. Default is MeshFlag.
MID
Name of the CAD attribute containing the PDM material ID info of the current part. Default is MaterialID.
Part number
Name of the CAD attribute containing the PDM part number info of the current part. Default is PartNumber.
PID
Name of the CAD attribute containing PDM property ID info of the current part. Default is PID.
Revision
Name of the CAD attribute containing PDM major revision info of the current part. Default is Revision.
Thickness name
Name of the CAD attribute containing the PDM thickness info of the current part. Default is Thickness.
UID
Name of the CAD attribute containing the PDM UID info of the current part. Default is UID.
Default versions of the _reader.ini files are included in the directory [Altair Home]/io/afc_translators/bin/[platform] directory and its children. When a CAD reader is activated, each reader first checks the current working directory for the appropriate _reader.ini file. If the file is not found, the translators looks in all directories pointed by the HW_CONFIG_PATH environment variable.
As a last resort, the translator uses the default _reader.ini file in the above directory. In this way the _reader.ini file can have "global" or "local" user scope. For instance, "local" user changes for a current job can be made by copying and modifying the _reader.ini file in the local current working directory.
Options can take on only one value at a time. Options can also be commented out (ignored) by placing a # in front of an option, in which case the default value for that option will be used.
The available _reader.ini options are explained in detail within the Import Options sections for each reader.
Many CAD translators also import other relevant information as metadata attached to specific entities (assemblies, components, points, lines, surfaces, solids). Some metadata is generated by default while other metadata is generated by enabling/disabling certain options in the _reader.ini files. Metadata is stored in the database and can be used for review or to perform process automation. For example, you can obtain the tag (name) of a surface from the CAD file and apply certain mesh criteria to that surface inside HyperWorks CFD. Refer to the Import Options topics for each format and CAD Metadata Naming for specific details about metadata.
