Combine Lines
Use the Combine Lines tool to create a new continuous line segment between two existing lines, resulting in a single seamless line.
  1. From the Geometry ribbon, click the arrow next to the Create tool group name, then select Combine Lines.
  2. Optional: On the guide bar, click to define connection options.
  3. Left-click to select lines to combine.
  4. On the guide bar, click Combine.
The following image shows an example of two lines combined into a single line.
Combine Lines Tool
An overview of the Combine Lines tool.
Figure 3.
Access
Go to Geometry > Create > Combine Lines.
Options
Smooth connect
Create curved connections between non-collinear lines, as shown in the following image.
Figure 4.
If left unselected, a straight line connection with angles is created.
Figure 5.
