Merge Solids or Surfaces
Merge two or more solids or surfaces. Solids are merged by removing shared faces while surfaces are merged by suppressing shared edges.
Merge Tool
An overview of the Merge tool.
Use the Merge tool to merge selected solids or surfaces. Solids are merged by removing shared faces while surfaces are merged by suppressing shared edges.
- Access
- Go to .
Options
- Feature angle based
- Enable surface merging based on feature angle. Rather than merging all selected surfaces, merge surfaces which have a greater angle than the user-defined angle.
- Feature angle
- The angle value that determines which surfaces should be merged. Any surfaces with an angle greater than this value will be merged.
- Remove scratch
- Remove baffle/fin surfaces after solid merge.
Merge Solids or Surfaces Using the Context Menu
Quickly merge solids or surfaces without opening the Merge tool.
