Combine Solids
Use the Boolean: Combine tool to connect two or more solids together, retaining all of the material in both.
Boolean: Combine Tool
An overview of the Boolean: Combine tool.
Figure 3.
- Access
- Go to .
Options
- Find tolerance
- Tolerance to use to find intersecting solids. By default, it is set as geometric tolerance.
- Keep common interface
- Retain any common surface, interface, after combining solids. This option is useful for conjugate heat transfer simulations where you want to retain the interface surface between two solids after combining.
Combine Solids Using the Context Menu
Quickly connect overlapping or intersecting solids without opening the Boolean: Combine tool.
