Remove Rounds and Fillets
Use the Defeature: Fillets tool to find and remove both round (convex) and fillet (concave) surfaces.
The Defeature: Fillets tool allows you to select a round or fillet, and find all that are larger, smaller, or similar (±5%) in size. In general, it is best to remove small fillets first, then larger fillets, then rounds. When you get to a point where you cannot remove any more, it is time to use other modeling tools and strategies to complete the geometry simplification.
![](../../../images/helpAnimationFillets.gif)
Defeature: Fillets Tool
An overview of the Defeature: Fillets tool.
![](../../../images/icons/icon_fillets.png)
Figure 3.
- Access
- Go to .
Find Options
- Minimum
- Change the minimum radius used to find features.
- Maximum
- Change the maximum radius used to find features.
Keyboard Shortcuts and Mouse Controls
To do this | Press |
Find larger fillets | Right-mouse click |
Find smaller fillets | Right-mouse click |
Find similar fillets | Right-mouse click |
