Stitch Surfaces
Use the Stitch Surfaces tool to stitch or unstitch adjacent and intersecting surfaces.
- Use window selection to select multiple surfaces, and simultaneously stitch adjacent surfaces and intersecting surfaces. Adjust individual edges if needed.
- Use the legend in the upper-left corner of the modeling window to assist you in finding edges. Edges are color coded by type. Show and hide an edge type by toggling its corresponding checkbox on and off, or quickly isolate an edge type by clicking Only.
Stitch Surfaces Tool
An overview of the Stitch Surfaces tool.
- Access
- Go to .
Options
- Maximum stitching distance
- Change the maximum distance across which the tool stitches edges together.
- Optimize surface quality
- Reconstruct geometry of selected surfaces to ensure consistency with the displayed topology.
- Stitching method
- Select a stitching method.
- Stitch edges options
- Select auto-stitching options
- Within same component
- Stitch created surfaces to neighboring surfaces that belong to the same component.
- Across any component
- Stitch created surfaces to all neighboring surfaces.
- From attached to selection
- Stitch created surfaces to surfaces attached to selected surfaces/edges.
- From selection only
- Stitch created surfaces to selected surfaces, or surfaces that have edges or vertices selected.
- Stitch free edges only
- Only stitch adjacent, non-shared edges.
Keyboard Shortcuts and Mouse Controls
To do this | Press |
Select surfaces. Click/drag points, edges. | Left Mouse Click |
Unstitch points, edges | Shift + Left Mouse Click |
Stitch Surfaces Using the Context Menu
Quickly stitch without opening the Stitch Surfaces tool.
