Create and Delete Elements
Use the Edit: Create tool to create new 1D, 2D tria, or 2D quad elements, and delete elements.
The Edit tools work for tessellated geometry. If the input is b-spline geometry, first convert to discrete geometry using the Convert tool.
  1. From the Geometry ribbon, FE Geometry tools, click Edit > Create.
    Elements are colored according to how well they adhere to the pre-set quality requirements defined in the criteria file.
  2. Optional: On the guide bar, click to to define the options used to edit elements.
  3. Select an element issue type from the guide bar.
    Quality
    Checks for quality as defined in quality criteria.
    Intersections
    Checks for intersecting elements.
    Face angles
    Checks for folded or sharp angle elements.
  4. Optional: Find all elements at or below a certain quality level.
    1. Click Find on the guide bar.
    2. Increase or decrease the number of layers around patches of failed elements by clicking or on the guide bar.
    3. Review the next or previous patch of failed elements by clicking or on the guide bar.
  5. Create or delete elements.
    • Select nodes to create 1D, 2D tria, or 3D elements.
    • Select the element(s) to delete, then left-click to delete element(s).
Edit: Create Tool
An overview of the Edit: Create tool.
Figure 3.
Access
Go to Geometry > Edit > Create.
Options
Intersections >
Set intersection tolerance to find out penetration level of two intersecting elements.
Face angles <
Set dihedral angle to find out sharp angle elements.
Element organization
Select the component in which elements are placed.
