Define Volume Mesh Local Settings
Use the Volume Mesh tool to define local volume mesh sizes on individual solids. You can also choose different volume mesh settings, such as defining layers on thin regions and quality controls.
These controls will not change the defined surface mesh controls; you must assign controls to solid body surfaces according to the sizes defined here.
  1. From the Mesh ribbon, Mesh Controls tools, click the Volume Mesh tool.
  2. Select solids.
  3. In the dialog, define volume mesh options.
  4. From the guide bar, execute the command in the following ways:
    • Click to confirm your selection and remain in the tool.
      This allows you to continue creating instances and helps you visualize and edit instances with the legend.
    • Click to confirm your selection and exit the tool.
