By Property Hierarchy
Figure 1. Solver Group 1. OptiStruct, Abaqus, Nastran
Figure 2. Solver Group 2. Radioss, ANSYS, LS-DYNA, PAM-CRASH, Permas
View new features for Engineering Solutions 2020.
HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
Explore the Engineering Solutions user interface.
The title bar displays the name of the file that is currently opened, along with the active product and user profile.
The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
Each toolbar contains a group of icon buttons that provide access to common tools.
The tab area organizes browsers, Utility menus for the solver interfacing user profiles, and other functionality not shown in the panel area in different tabs.
The modeling window displays your model, geometry and plots.
Quickly find and open the tools, panels, and browsers that are available from the menu bar pull-downs or from the Utility Browser, as well as create solver cards.
The status bar displays information pertaining to the currently loaded model as well as descriptions of the pages and panels.
Undo and redo actions performed in Engineering Solutions.
Use the Visualization controls to change many of the visual states in Engineering Solutions and HyperView.
Input controls allow you to manipulate your methods of entering and controlling different aspects of Engineering Solutions.
Engineering Solutions requires the use of different types of data files, from its own database files which contain data on model geometry, mesh, loads, boundary conditions, and so on, to property cards, master weld files and many more.
Engineering Solutions uses the proprietary (.hm) format for database files which include geometry, meshing, connectors, loads and forces, materials, and everything else that is necessary to pre-process a model prior to sending itto a solver.
BINARY database files are the primary files used by Engineering Solutions and use the file extension .hm.
In Engineering Solutions various file types can be imported into the selected client. The Import tab allows you to input external CAD line and surface data or finite element models. You can also import/merge model files (.hm) into the current model session.
Import external CAD line and surface data or finite element models. You can also import/merge HyperMesh model files (.hm) into the current model session.
Import solver input files.
Import options used to determine how FE models are imported.
Overview of how entities are imported.
When an external input translator is used to import data, Engineering Solutions creates a file for messages in the directory in which the program was started.
The Solver Options button opens a dialog with the different options available. The contents of the dialog vary according to the user profile you have selected.
Model organization options are used to define how a model is imported into Engineering Solutions.
Import CAD files.
IDs that are duplicated within element and property groups for the LS-DYNA user profile are supported in Engineering Solutions.
In Engineering Solutions exporting various file types from the selected client to another format. The Export tab allows you to export a model to CAD line and surface data or finite element models.
Most FEA solvers allow you to organize the input deck into separate files and provide a mechanism to include (or refer) these files in the master input deck.
Configure the view and behavior of Engineering Solutions.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Setup an Optimization in Engineering Solutions.
