By Window
Use the By Window option in the Extended Entity Selection menu to create a window that can be used to select entities on your model.
Figure 1. Window Selection
Panel Options
Option | Action |
points | Draw a window by selecting points in the modeling window. |
interior | Select all entities within the window.![]() Figure 2. Interior Window Selection |
exterior | Select all entities outside the window.![]() Figure 3. Exterior Window Selection |
visible only | When disabled, only the visible elements inside of the
selection window are taken into account. Visible means that the
element centroid is visible (for solids at least one faces
centroid). Select this checkbox to take into account all of the elements inside of the selection window. |
Command Buttons
Button | Action |
select entities | Select the entities shown in the modeling window. |
reject entities | Reject the selection. |
delete window | Delete the current window. |
return | Exit the panel. |
