Edit Curves Panel
Use the Edit Curves panel to create new curves or edit existing ones.
Each vector can be defined using either a data file or a math expression. For example, the data source for the x vector could be a file, and the data source for the y vector could be a math expression. The data sources for the x and y vectors are displayed in the x = and y = fields.
Create Subpanel
Option | Action |
plot | Select the plot on which to create the curve. An untitled plot is created if no plot currently exists. |
x / y | Display the data sources for the x and y vectors once they are selected. |
file | Browse to a file that contains your curve data. |
type |
Select a data type.
Note: Only available when file is
selected.
req | Select a data request set. |
comp | Select a component. |
math |
Use
a math expression for your curve data.
Note: The math expression must evaluate to an
array.
Modify Subpanel
Use the Modify subpanel to edit an existing curve by changing the data source for the x or y vector or by applying a mathematical expression.
- c1.x
- To reference the x vector of curve 1.
- c1.y
- To reference the y vector of curve 1.
- x = 0:6.14:.01
- y = sin (x)
Figure 1. Example 1: Edit Curves
- x = c1.x
- y = polyfit(c1.x, c1.y, 3)
Figure 2. Example 2: Edit Curves
Option | Action |
curve | Select the curve to modify. |
type |
Select a data type.
selected.
math |
Use
array.
