Global Model Validation
Checks for the validation of a global FE model.
Restriction: Only available in the Nastran solver in the Aerospace user profile. The checks can be run for any type of model, but their implementation is strictly meant to validate a global FE.
From the menu bar, click Aerospace > Check > Global Model Validation.
Check Descriptions
Table 1. Errors
Name Description Result Auto correction action Investigate action
Aspect Ratio Checks for 2D element aspect ratio wrt value limit defined in the check (default = 5). Lists the failing elements and the found values. Not supported. Opens the QI Index panel.
Taper Ratio Checks for 2D element taper ratio wrt value limit defined in the check (default = 0.8). Lists the failing elements and the found values. Not supported. Opens the QI Index panel.
Warping Checks for 2D element warping wrt value limit defined in the check (default = 10). Lists the failing elements and the found values. Not supported. Opens the QI Index panel.
Skew Angle Checks for 2D element skew angle wrt value limit defined in the check (default = 60). Lists the failing elements and the found values. Not supported. Opens the QI Index panel.
MPC Consistency Checks if the nodes of any MPC have been assigned to the same output (analysis) system. Lists the failing elements. Not supported. Opens the Matrix Browser with selected equations with the list of nodes and relevant systems.
RBE Consistency Checks if the nodes of any RBE have been assigned to the same output (analysis) system. Lists the failing elements. Not supported. Opens the Matrix Browser with selected elements with the list of nodes and relevant systems.
Table 2. Warnings
Non Zero CELAS Length Checks for CELAS elements that have a length > 0. Lists the failing elements and their GA and GB nodes. Not supported. Invokes the Matrix Browser with selected elements with the list of nodes and relevant system including node coordinates and property characteristics.
CELAS System Checks if the nodes of any CELAS have been assigned to the same output (analysis) system. Lists the failing elements and their GA and GB nodes. Not Supported. Invokes the Matrix Browserwith selected elements with the list of nodes and relevant system including node coordinates and property characteristics.
3D Element Connectivity (Negative Volume) Checks solid element with negative volume. Lists the failing elements and the found values. Not supported. Not supported.
Table 3. Info
Element Coordinate System Checks the element coordinate system. Dummy vector is reported to invoke the Investigate option. Not supported. Invokes the Orientation Review tool displaying element coordinate system.
Material Coordinate System Checks the element material system. Dummy vector is reported to invoke the Investigate option. Not supported. Invokes the Orientation Review tool displaying element material system.
2D Element Connectivity Checks the 2D element X direction. Dummy vector is reported to invoke the Investigate option. Not supported. Invokes the Orientation Review tool displaying element X axis for 2D.
Coincident Nodes Checks the coincident nodes wrt tolerance given as value limit (default = 0.0049999999). Lists the coincident nodes. Not supported. Opens the Nodal Equivalence tool.
Free Edges Runs the standard Free Edge check of HM. Creation of the ^edge component. Not supported. Opens the panel edges.
Coincident Elements Checks for coincident elements. Lists the failed entities. Not supported. Not supported.
Normals Checks 2D element normals. Dummy vector is reported to invoke the Investigate option. Not supported. Opens the Normal panel.
1D Element Offset (BAR/BEAM) Checks the offset and or neutral axis for bar/beam elements. Dummy vector is reported to invoke the Investigate option. Not supported. Invokes the Beam Review tool.
2D Element Offset Checks offset of 2D elements. Dummy vector is reported to invoke the Investigate option. Not supported. Invokes dedicated small selector to activate the 2D Detailed element representation.
CONM2 Offset Checks mass and offset for CONM2 elements . Dummy vector is reported to invoke the Investigate option. Not supported. Invokes dedicated GUI to control the display, with normalized scaled mass, of CONM2 elements considering their given offset.
