Rivet Certification
Figure 1. Lap Joint Geometry
Figure 2. FE Idealized Model to Extract Forces and Fluxes
The Mesh Independent/Mesh Dependent options act as an up-front filter on selection before absorb APIs. The later finds in the remaining selection the rivets as an ordered collection of pierced shells and 1D elements (for body). There can be a long chain of multi-layers (more than two shells) resulting in double shear plates. The body must be made of a single (non-zero length) 1D element to be recognized.
Structural Properties
The stuctural property of config rivet has a single data name to store rivet diameter. In Auto DDP, the Aborb FE option is only valid for CFAST formulation. The tool "drills down" to PFAST properties assigned to CFAST elements used by a design point. The PFAST diameters are retrieved and as soon as all diameters are the same, a structural property entity is created with the same diameter value and assigned to the design point automatically.
JointLoad Method
The rivet config has an internal method called JointLoad. This method extracts rivet forces/fluxes and moments on each and every layer (pierced shells) of a rivet and populates a table with all of the extracted data. It does not compute margin of safety, therefore it cannot be contoured.
Figure 3. . Box length=0.4*Size_scale*(D_scale*Diameter)
Figure 4. Review Extraction Areas per Plate
