Morphing
The morphing capabilities of Engineering Solutions enable you to generate new designs based on an existing mesh, in a simple and quick manner, and can be accessed via the Morphing option in the menu bar of the CFD user profile.
Figure 1. Morph Volumes
Different approaches to mesh morphing that are well suited for CFD applications are available. A wide range of constraints are provided to restrict the movement of nodes during morphing, for example to deal with non-matching interfaces or to preserve the boundary layer thickness. The following section gives a short description of some morphing capabilities well suited for CFD applications.
