Connector Definition
A connector definition describes the connection between multiple entities at a specific location.
- node
- node list
- geometric point
- line
- line list
- surface
- elements
- tags
Any number of link entities of differing types can be added to a connector in any order. The connector sets the order of link entities during the realization process.
Example: Connect Assemblies
The projection behavior for connecting assemblies.
- Assem 1 contains Comp 1 and Comp 2
- Assem 2 contains Comp 3 and Comp 4
A connector is created with the Links as Assem 1 and Assem 2, and the number of layers set to 3.
During realization the closest found components residing inside the 2 assemblies will be retained as the component links.
