Seatbelt System
Use the Seatbelt Browser to create a complete seatbelt system.
Restriction: Only available in the LS-DYNA,
Radioss and PAM-CRASH
solvers.
From the menu bar, click Safety > Seatbelt.
The Seatbelt Browser opens.
To undo or redo actions, use the
Undo and Redo commands on
the Restore toolbar.
The Seatbelt Browser consists of two panes. The upper pane is the Seatbelt System structure and the lower pane is the Entity Editor.
- Add or remove columns in the Seatbelt Browser as necessary by right-clicking on a column and checking or unchecking the appropriate attribute.
- You can sort entries in the browser by clicking on the appropriate heading of each column. For fields that are numeric or alphanumeric, repeated clicks toggle between ascending and descending order.
Create a seatbelt system:
In the Seatbelt Browser pane, in empty space,
right-click and select Create > SeatbeltSystem.
A seatbelt system is created and displayed in the browser.
Edit the seatbelt system entity as necessary by setting or changing
values in the Entity Editor.
For more information on seatbelt entities and attributes, see Seatbelt Browser Entities and Attributes.
To update a seatbelt system, right-click on the appropriate
SeatbeltSystem entity and select
Update from the context menu.
Updating allows you to make changes on demand. For example, when the dummy and seat positions have been modified (when the option Link Dummy Mechanism in the seatbelt system entity editor is OFF).
Run a penetration check on the system by right-clicking on the appropriate
SeatbeltSystem entity and selecting
Penetration Check from the context menu.
A penetration check allows you to directly check the generated contact for penetrations after a seatbelt mesh has been generated and the option Create Contact is activated.
