Unload Subsystem Representations
Unload subsystem representations from a session.
View new features for Engineering Solutions 2020.
HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Subsystem representations allow a single subsystem to have multiple CAE representations that can be loaded into the session interchangeably.
Once you have created a subsystem and populated it with content, you can save the representation locally or save a revision to the Subsystem Library.
Subsystem representations can be added from external sources such as solver decks.
Subsystem representations can be added from external sources such as a subsystem library.
Add representations to the library if they are in session.
Subsystem representations can be loaded from the current HyperMesh session.
Subsystem representations can be loaded from the subsystem library.
Subsystem representations can be deleted from the current HyperMesh session.
Subsystem representations can be deleted from the Part library.
Use the Library Viewer to review subsystem library content.
Manage, control, and update Major, Study, and Library subsystem revisions using the Subsystem Library.
Also referred to as Postgres, PostgreSQL is an object-relational database management system with emphasis on extensibility and standards compliance.
Setup an Optimization in Engineering Solutions.
