report
Report outputs and visualization configuration.
Settings
- advance
- true = Advance style report with MultiCPU, false = Normal style report with 1CPU.
- avoid_duplicate_slide
- true = duplicate slides avoided, #duplicate issues shown under instance, false = all of the issues for single pairs will be reported.
- bg
- Background colors to be used for creating H3D files and images.
- color
- Default colors for various check results.
- transparency
- Transparency settings.
- intersection
- Visualization related settings for intersection reporting.
- spotweld
- Setting related to spot weld check reporting.
- hvp
- DO NOT CHANGE.
- max-record
- Supported values: 50
- template
- The file name of the MS PowerPoint template to be used for reporting.
- template-sheet
- Name given to template.
- skip-assembly-image
- Parameter to skip assembly image in Comparison PowerPoint (checkbox).
- template-ppt
- Path of the power point template.
- percentage-sequence
- This is the parameter for arranging the order of thumb nail images of components in the PowerPoint.
- resultslide
- This is the parameter to get the default multiple slides for multi-variant comparison or to get single slide which shows the best match result.
- threshold_report
- This is an intermediate percentage value to be given between threshold value and maximum value. The components having match percent value between threshold and threshold_report value is shown in green color and the components with value between threshold_report and maximum value in gray color.
- result-review
- Result display setting after comparison check is completed. The
following options can be selected to display unmatched entities on
graphics.
- tempNodes
- Displays unmatched area as temp nodes.
- tempComps
- Displays unmatched area as elements in red color.
- tempComps+Node XYZ
- Displays unmatched area as elements in red and exports unmatched nodes in a text file working folder.
- legend-detailed
- Applicable for Quick Comparison flag ON, unmatched elements are shown in red color.
- legend-overview
- Applicable for Quick Comparison flag ON, unmatched elements are not shown in red color showing high level results.
- range-legend-level
- Applicable for Quick Comparison flag ON. Comparison legend left tab Ranged's number of levels are controlled by these values. 0 to 100% values are split by these values. An example in case of 30-90% match results exist, 90-30/7=8.57 splits will be shown.
- threshold-ranges
- Applicable for Quick Comparison flag ON. Comparison legend right tab Discrete's levels are controlled by these values. The accepted value is from 30 to 99.9 with spaces between values.
- thumbnail-assemblyImageColor
- Applicable for quick Comparison flag ON. Part color shown inside the assembly thumbnail image, it is in the 2nd page of the Powerpoint report.
- thumbnail
- Text displayed below thumbnail image, supports PID or Part Name. It is in the 2nd page of the Powerpoint report.
- max-slide
- Maximum number of slides to be included in the PPT file.
- ignore_part_Instance
- Ignores part instances from intersection check and report. This is applicable if the number of parts in the model are more then 300.
- ignore_name_Instance
- Ignores parts if their Part Names and Part Number are almost the same from intersection check and report. This is applicable if the number of parts in the model are more then 300.
- display_intersection_depth
- Displays intersection depth value in a text box inside HyperView player.
- text-static
- You can enter the information.
- max-slide
- text-static
- max-slide
- template
- text-static
- max-slide
- template
- layout
- DO NOT CHANGE.
- text
- description
- DO NOT CHANGE.
- project
- DO NOT CHANGE.
- id
- DO NOT CHANGE.
- date
- DO NOT CHANGE.
- text-static
