Frequency Set Manager
Create standard analysis frequency sets that will be automatically used in setting up analysis frequencies in NVH analysis.
The Frequency Set Manager is invoked by clicking the icon, which opens the Manage
Frequency Set dialog.
To add frequency sets, click the icon, which opens the Define Frequency Set
dialog, enter a name in the Frequency Set name field, select a frequency increment type in
the Incr type field, and then enter appropriate values into the Min, Max, and Incr size
fields. When completed, click Update to save changes made to
frequency sets or click Cancel to discard changes made since the last
update, and exit the dialog.
To edit a frequency set, highlight the row corresponding to the frequency set, and then
Define Frequency Set dialog, and edit the appropriate fields. To
delete a frequency set, highlight the row corresponding to the frequency set, and then click
the
icon.
To select frequency sets as the active standard frequency set, highlight the appropriate rows and click Select.
