Panel Set Manager
Create panel sets by selecting nodes/elements and/or existing node sets in the model file, that will automatically be used in setting up Panel Participation diagnostic output in NVH analysis.
The Panel Set Manager is invoked by clicking the icon, which opens the Manage Panel Set
dialog.
To add a panel set, click the icon, which opens the Define Panel Set dialog,
enter a panel set name in the Panel Set name field and then select a set of grids,
components, or elements using the entity selector. When completed, click
Create to create the panel set or click
Cancel to discard changes made, and exit the dialog.
![](../../../images/icons/edit-24.png)
![](../../../images/icons/delete-24.png)
![](../../../images/icons/display-24.png)
![](../../../images/manage_panel_set_dialog.png)
![](../../../images/define_panel_set_dialog.png)
![](../../../images/manage_panel_set_model.png)
Figure 3.
