Remove Links
Remove links from one or more connectors at a time.
Remove Links is available from the Connector Entity Browser's context menu when you right-click in the Entities or Link columns.
Once links are removed, updated connectors will be unrealized and your changes will be permanently updated in the database and browser.
Remove All Links From Connectors
Remove Specific Links From Connectors
- Select the link(s) to remove, then right-click and select Remove Links from the context menu.
- In the Confirm dialog, click Remove link.
