Organize Settings
Determine which dependent entities to move when managing subsystem content and behavior if entities are shared across subsystems.
Overview
When moving an entity into a subsystem there are customizable options that determine which dependent entities would also be organized into the subsystem. For example, moving a component by default will also move the associated nodes, elements, properties and materials.
There are secondary options that determine the action if the entity is shared (has multiple references). For example, when moving a property, the material should also move to the subsystem if a different property also references the same material.
