Load Step: Restart Write
Select Restart write in the tree to define the *RESTART, WRITE card.
View new features for Engineering Solutions 2020.
HyperWorks Engineering Solutions is a modeling and visualization environment for NVH, Crash, CFD, Drop Test and Aerospace using best-in-class solver technology.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
The Drop Test Manager is an automated solution that allows you to either simulate a single drop test or a choice of multiple iterations with the aim of finding the sensitivity of process variables like initial orientation and drop height in a typical drop test by controlling the run parameters and conditions with ease.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Learn the basics of working with browsers.
Use the Assembly Browser to manage parts and modules during the assembly building process.
Use the Connector Browser to view and modify connectors in the current model.
Use the Contact Browser to create, review and modify contact interfaces and surfaces in a model.
The Entity Editor enables you to quickly view and edit entities in a model and correctly setup solver information.
Use the Entity State Browser to set various states for entities in a model.
Use the Loadsteps Browser to create, manage and display loadsteps (sub-cases) and the associated control cards.
In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
Use the Mass Trimming tool to create, define and realize mass entities.
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
Use the Model Browser to view the model structure while providing full find, display and editing control of entities.
Check the solver validity of the model, identify modeling issues, and fix modeling issues in an automatic or manual way.
Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
Create, organize and manage the CAE subsystem level models using any entities.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have Engineering Solutions-supplied and user-defined macros associated with them.
The QA Utility menu contains many tools to help you quickly review and clean up the quality of a pre-existing mesh.
In the Disp Utility menu, clear temporary nodes if needed.
This menu contains a set of macros related to working with model geometry, as well as a set for working with FE mesh.
Macros are included on the Abaqus page of the Utility menu when you load the Abaqus user profile.
Use the Tie-Comparison tool to compare Tie-Contacts created in Engineering Solutions to Tie-Contacts created by the Abaqus solver.
Use the Abaqus Contact Manager to create, edit and review cards.
The Dummy Positioning Process Manager tool guides you through the workflow of positioning a dummy in a seat.
Use this tool to align the face1 of selected solid elements (hexa and penta) to match with a planar face.
Use the Step Manager to create, edit and review supported keywords.
Procedures used to navigate you through the Step Manager dialog.
You can create, edit, review, rename, reorder, and delete load steps from this tab as well as set the export and display status of the load steps.
Use the Load Step dialog to define the *STEP-*END STEP block as well as the associated Abaqus history keywords.
You can create, edit, review, rename, reorder, and delete load collectors from this table. You can also organize (copy or move) loads into load collectors and edit the load labels here.
Select Title to define a one line title or sub-heading for the load step.
Select Parameter to define the parameters of the *STEP card.
Select Analysis procedure to define the analysis type of the load step.
In the Boundary dialog, define and edit the *BOUNDARY card.
In the CLOAD-Force dialog, define the *CLOAD card for dofs 1 through 3 and the CLOAD-Moment for dofs 4 through 6.
In the CFILM dialog, define the *CFILM card on node sets.
In the CRADIATE dialog, define the *CRADIATE cards on node sets.
In the DLOAD dialog, define the *DLOAD cards on individual elements or geometry (surfaces). You can also define the DLOAD on element sets.
In the FILM dialog, define the *FILM cards on individual elements or geometry (surfaces). You can also define the FILM on element sets.
In the RADIATE dialog, define the *RADIATE cards on individual elements or geometry (surfaces). You can also define the RADIATE on element sets.
In the DSLOAD dialog, define the *DSLOAD card on Abaqus surfaces (*SURFACE).
In the SFILM dialog, define the *SFILM card on Abaqus surfaces (*SURFACE).
In the SRADIATE dialog, define the *SFILM card on Abaqus surfaces (*SURFACE).
In the Temperature dialog, define and edit the *TEMPERATURE card.
In the Inertia relief dialog, define and edit the *INERTIA RELIEF card.
The Interface Controls option defines Abaqus keywords.
Use the Output requests option define output options for ODB, result (.fil) and data (.dat) file formats.
Select Monitor to define the *MONITOR card.
Select Print in the tree to define the *PRINT card.
Select File format in the tree to define the *FILE FORMAT card.
Select File output in the tree to define the *FILE OUTPUT card.
The Unsupported cards option in the tree enables you to review and edit unsupported history data within the Step Manager.
Create, edit, review, rename, reorder and delete load cases from this tab as well as set the display status of the load steps.
Search the entity names in your model for every occurrence of a specific character, and automatically replace the character with a new one that you specify.
The macros on the ANSYS Utility menu simplify some common tasks for the ANSYS user profile.
The LS-DYNA Utility menu contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
The Nastran user profile contains two macro menus on the Utility menu: Nastran1 and Nastran.
The PAM-CRASH 2G Utility menu (pamcrash2G.mac) contains shortcuts and tools that help simplify PAM-CRASH 2G tasks.
The Utility menu for the OptiStruct user profile contains, in addition to the default Utility menus, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
Use the Visualization controls to change many of the visual states in Engineering Solutions and HyperView.
Setup an Optimization in Engineering Solutions.
The supported attributes are Overlay, Frequency, Number interval and Time marks.
Click Update to activate the monitor attributes defined in the Engineering Solutions database.
