abstat_mat
Option | Description | Supports |
ABSTAT | Airbag statistics. Reads airbag and blocked materials statistics from LS-DYNA files into HyperGraph 2D. The data read in is sorted by time steps specified in the input file. |
Volume, pressure, internal energy, input mass flow rate, output mass flow rate, mass, temperature, density. |
