Apply Style
Select and apply attributes of the current plot to either every plot on every page or to every plot on the current page.
You can access the Apply Style dialog from the HyperGraph 2D Tools menu, sor by right-clicking within HyperGraph 2D and selecting HG Apply Style from the context sensitive menu.
From the drop-down menu under Pre Selection, select Current Page, All Pages or Last Selection.
- Current Page
- Applies the attributes of the current plot to the other plots on the current page.
- All Pages
- Applies the attributes of the current plot to the plots on every page.
- Last Selection
- Applies the attributes of the current plot to the previously selected curve.
The following attributes can be selected from the dialog. Place a check mark in the box to select the attribute that you want to apply. Upon opening the dialog, attributes that already have a check mark next to them are selected by default.
- Plot
- Background color
Frame color
Gridline color
Zero line color
Bar gap (Disabled if the current plot is not a bar chart).
Bar stacking (Disabled if the current plot is not a bar chart).
Complex axes (Disabled if the current plot is not a complex plot).
+/- 180 Phase constraining (Disabled if the current plot is not a complex plot).
- Legend
- Font
Border thickness
Leader position
Color
Location
Visibility
- Header/Footer
- Primary font
Secondary font
Tertiary font
Color
Alignment
Visibility
- Axes
- Apply to: Primary horizontal, Primary vertical, All
secondary
Attributes: Label, Label font, Tic font, Color
Formatting: Axis scaling, Min, Max, Tic method, Increment, Number of tics, Number of grids, Numeric format, Numeric precision, Autofitting, Fit to range
- Curves
- Line style
Line thickness
Line color
Symbol
Symbol color
Symbol increment
Bar fill pattern - Disabled if the current plot is not a bar chart.
- Notes
- Font
Border thickness
Color
Alignment
- Page Title
- Font
Visibility
- Selects all the options on the dialog.
- Deselects all the options on the dialog.
- Reverses the selection for each option. For example, a selected check box becomes unselected.
- Apply
- Applies the selected options to the current page or all pages (whichever you have selected).
- OK
- Applies the selected options to the current page or all pages (whichever you have selected) and closes the dialog.
- Close
- Closes the dialog.
