View new features for HyperGraph 2D 2020.
Discover HyperGraph 2D and HyperGraph 3D functionality with interactive tutorials.
Powerful data analysis and plotting tool for all types of CAE data.
HyperGraph 3D offers a 3-D plotting environment that is fully integrated with HyperWorks, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks Desktop applications.
The HyperGraph 3D menus provide quick access to panels and tools.
Provides quick access to the Axes and Notes panels.
The HyperGraph 3D context sensitive menu is activated by right-clicking within the window area of the application.
Each toolbar contains a group of icons that provide access to common tools.
The Tab Area is the portion of the graphical user interface that contains the browsers, utilities, and other functionality not shown in the panel area.
The Plot Browser resides on a tab in a tab area sidebar. It displays your sessions's current plot data in a tree structure.
The HyperGraph 3D panels allow you to manage, review, and analyze 3-D plots such as waterfall, surface, and 3-D line data.
Create Curves by File loads Flux motor efficiency files in text format.
Use the Define Curves panel to edit existing curves or add new curves to the current plot.
Create waterfall plots from XY force response data and input pulses.
The Datum Planes panel allows you to insert reference datum planes to plots.
The Data Query panel uses vertical cutting surfaces for viewing and plotting non-planer cross sections.
Curve attributes, such as line style, color, and weight as well as symbol style and color and data attributes, are located on the Curve Attributes panel.
Allows you to retrieve individual point data on any curve in the active window.
The following sections describe support for various solvers in HyperGraph.
Axes can be added to plots using the Axes panel.
ON THIS PAGE
ON THIS PAGE
