Create Curves by File
Use Create Curves by File to plot curves for multiple runs and multiple subcases for a component.
You can use the Build Plots dialog and the Create Curves by File dialog together to plot data. The features found on the Create Curves by File dialog are the same as those on the Build Plots panel. To return to the Build Plots panel, click Panel from the Create Curves by File dialog.
