Datum Lines
Allows you to add horizontal and vertical datum lines to plots.
Text
Create a label for a datum line.
Position
Position a datum line label. You can select Phase/Magnitude or Real/Imaginary.
Line Attributes
Set the attributes of a datum line. Click Use Preferences to use the preferences set in the preferences.mvw file.
A datum line can be hidden or displayed on a plot by activating the Datum check box.
Use the drop-down menu next to the Datum check box to switch between horizontal and vertical datum lines.
Datum lines can be cut, copied, pasted, or added.
