HyperGraph
HyperGraph
  1. Home
  2. Get Started
  3. User Interface
    The user interface provides you with a consistent look and feel when you are working in any of the HyperWorks Desktop applications.
  4. NVH
    From the HyperGraph 2D NVH menu, the following options are available.
  5. Grid Participation
  • What's New
  • Get Started
  • Tutorials
  • HyperGraph 2D
  • HyperGraph 3D
  • HyperGraph Solver Interfacing
Index
HyperGraph
HyperGraph
  • What's New
    View new features for HyperGraph 2D 2020.
  • Get Started
    • Supported Files in HyperGraph 2D
      HyperGraph 2D can read the following types of plot data files:
    • User Interface
      • HyperGraph 2D Menus
        The HyperGraph 2D menus provide quick access to panels and tools.
      • HyperGraph 2D Toolbars
        The HyperGraph 2D toolbars provide quick access to commonly used panels and tools.
      • Tab Area
        The Tab Area is the portion of the graphical user interface that contains the browsers, utilities, and other functionality not shown in the panel area.
      • Plot Browser
        The HyperGraph 2D Plot Browser resides on a tab in the tab area sidebar and allows you to view the HyperGraph 2D plot structure.
      • NVH
        • Load the NVH Utilities Preferences File
        • Integrated Diagnostics
        • Modal Participation
          Allows you to plot modal/panel participation curves from an OptiStruct .h3d file or an MSC Nastran .f06/.pch file.
        • Grid Participation
        • Energy Distribution
          Visualize the distribution of energy within a full vehicle NVH model, as a way to understand what components are dominating the vehicle response.
        • Transfer Path Analysis
          Identifies the complex contribution of the excited structure through attachment points to a response in the responding structure.
        • Design Sensitivity Analysis
          Design sensitivity represents a change in response with respect to a change in a design variable, which is typically used for optimization.
        • OrderCut Analysis
          Generates and post-processes engine order related data from an OptiStruct or Nastran frequency response analysis that contains either RPM-based loading subcases or order-based loading subcases.
        • Modal FRF
          Calculate a frequency response based on modal results.
        • Model Correlation
        • Radiated Sound
          The Equivalent Radiated Sound utility post-processes the results of exterior structure-borne radiated sound.
        • Global Modes
          Identifies global modes from an OptiStruct or Nastran modal analysis.
        • Mount Optimization Utility (HyperGraph 2D and HyperView)
          The Mount Optimization utility helps to predict powertrain rigid body mode frequencies and kinetic energy distribution, which play a critical role in optimizing the mount stiffness and layout configuration, by decoupling powertrain rigid body modes and reducing vibration transmission.
        • Multiple Sample Analysis
          Post-process results from a Multiple Sample Analysis, including plotting a spread of responses (+/-95% and mean).
        • Optimization, RBDO
          Allows optimization of sensitive parameters for multiple sample analysis results using the RBDO approach.
        • Display Options
          Customize plots using the following options
        • Filter Contributors
          Filters contributors to a smaller set of data.
      • Vehicle Safety Tools
        The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
      • Model Identification Tool
        The Model Identification Tool, known as MIT, is a profile in HyperGraph 2D for fitting test data from frequency- and amplitude-dependent bushings to analytical models.
  • Tutorials
    Discover HyperGraph 2D and HyperGraph 3D functionality with interactive tutorials.
  • HyperGraph 2D
    Powerful data analysis and plotting tool for all types of CAE data.
  • HyperGraph 3D
    HyperGraph 3D offers a 3-D plotting environment that is fully integrated with HyperWorks, for managing, reviewing, and analyzing 3-D plots such as waterfall, surface, and 3-D line data.
    The following sections describe support for various solvers in HyperGraph.
HyperGraph
HyperGraph
  1. Home
  2. ...
    • User Interface
    • Get Started
    • NVH
  3. Grid Participation
  • What's New
  • Get Started
  • Tutorials
  • HyperGraph 2D
  • HyperGraph 3D
Index
ON THIS PAGE
    Grid Participation
    For more information on Grid Participation, see the NVH Grid Participation Utility topic in HyperView
    ON THIS PAGE
