HyperGraph 3D Toolbars
Each toolbar contains a group of icons that provide access to common tools.
Toolbars can be turned on or off from the View menu. A check mark indicates that a toolbar is currently displayed.
Toolbars are dockable, meaning they can be positioned anywhere within the window by
hovering over the four dots, , and dragging them with your mouse to its new
location.
The following toolbars are available in HyperGraph 3D.
To access a panel, click on the corresponding panel icon on the toolbar.
Curves
Annotations
Display
Displays the vertical toolbar on the left-hand side of the graphics area. The Display
Control icon, , is located on the vertical toolbar.
Figure 3.
