User Interface
Explore the HyperLife user interface.
The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperLife. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools. The Results Browser allows you to view the HyperLife model structure while providing find, display, and editing control of entities. Use the Entity Editor section of the Results Browser to view and edit various entity conditions/properties. Use the entity selector to specify which type of entity you are able to select. The modeling window is where your model is displayed. View controls enable you to control the view and display of your model in the modeling window. The status bar displays information pertaining to the currently loaded model. View your model in motion using animation controls.
  1. Menu Bar
    The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help.
  2. Ribbons
  3. Results Browser
  4. Entity Editor
  5. Entity Selector
  6. Modeling Window
  7. View Controls
  8. Status Bar
  9. Animation Toolbar
