Remove options from the Load Map dialog.
From the Setup tools, click the
Load Map tool.
The Load Map dialog opens.
On the top half of the dialog, select a load channel and click
to delete it.
On the bottom half of the dialog, select an event or a subcase associated with
an event and click
to delete it.
