Load Maps
Use the Load Map tool to import/create multiple channels (load histories) which are then paired with subcases/loadsteps to create the fatigue events.
The Load Map dialog consists of three parts. The top-left part is used to create, import, and manage the channels (load histories); the top-right part displays the available subcases; and the bottom part is used to create events.
The information displayed in this dialog is dynamic. The available options change depending on the load type and the channel type.
Type of Loading | Channel Type |
Time Series | Time
Data Constant Amplitude Block Loading |
Transient Response | Transient Response |
Modal Superposition | Eigen Value
(*.pch) CMS (*.mrf) |
Random (PSD Stresses) | PSD Stress |
Random (Input PSD with FRF) | Input PSD: Phase and
Magnitude Input PSD: Real and Imaginary |
Sine Sweep | Constant Load Variable Scale |
