HyperLife Overview
A comprehensive fatigue solutions framework.
HyperLife is an easy-to-learn fatigue analysis software developed on a solver-neutral framework. It provides a comprehensive tool set for durability analysis, directly interfacing with all the major finite element analysis (FEA) and multi-body dynamics (MBS) result files. With an embedded material library, HyperLife offers solutions for fatigue life predictions under static and transient loading across a wide range of industrial applications.
Benefits
  • Easy to learn and easy to use graphical interface to perform Fatigue Life predictions.
  • Solver neutral framework interfacing leading FEA results data.
  • Embedded material database.
  • Specialty module to perform simultaneous fatigue analysis on base material and welded joints according to numerous design codes and guidelines.*
  • Customizable environment to add new or in-house functionality.*
*Beta version in the 2019 release.
Options
Table 1.
    Stress State Mean Stress Correction Plasticity
SN Uniaxial
Abs Max Principal
Max Principal
VONMISES
Signed von Mises
TRESCA
Signed TRESCA
Signed Max Shear
X Normal
Y Normal
Z Normal
X-Y Shear
Y-Z Shear
Z-X Shear
GOODMAN (Default)
GERBER
GERBER2
SODERBERG
FKM
NA
Multiaxial NA (Stress tensors are directly used)
GOODMAN - Tension damage model
FKM - Tension damage model
FINDLEY - Shear damage model
NA
EN Uniaxial
Abs Max Principal
Max Principal
Min Principal
VONMISES
Signed von Mises
TRESCA
SGTRESCA
Signed Max Shear
X Normal
Y Normal
Z Normal
X-Y Shear
Y-Z Shear
Z-X Shear
Smith-Watson Topper (SWT)
MORROW
MORROW2
Neuber
Smith-Watson Topper (SWT) - Tension damage model
Fatemi-Socie Model (FS) - Shear damage model
Brown-Miller Model (BM) - Shear damage model
Jiang's plasticity model - Non-proportional loading
Default, not exposed.
Table 2.
Welds Method Mean Stress Correction Weld Elements Plasticity
Seam VOLVO
None (Default)
FKM
Shell elements NA
Spot RUPP
None (Default)
FKM
Cbar
Cbeam
Cweld
Chexa
NA
