Access the Context Menu
The context menu options allow you to globally control the status of the folders in the Loadsteps section list.
  1. Do one of the following:
    • From the Query tools, click the Loadcase tool.
    • Right-click in the Results Browser and select Create > Derived Load Case then a load case type.
    The Create/Edit Derived Load Case dialog is displayed.
  2. Right-click anywhere within the Loadsteps section list.
    The context menu is displayed.
  3. Click on one of the available options.
    Collapse All Closes all model folders in the entire tree structure.
    Expand All Opens all model folders in the entire tree structure.
