The ribbon allows you to quickly access tools and standard functions, and is located along the top of HyperLife. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
The Message Log lists the actions performed in the current session. The dialog also provides you with information about your file
(warnings, errors, and so on).
Quickly display all entities of a specific type in the Results Browser.
In the Results Browser, double-click on an entity or
collector to open its respective view.
All entities of that type will display in a flat list. Depending on the
type of entity selected, additional columns may be appended to the Results Browser. The color of geometry and mesh in the modeling window will be changed if the entity type selected
has a corresponding color mode.
To return to the default view and display all entities in the Results Browser, click .
