Weld Line Browser
The weld line browser organizes the weld lines that have been detected in the model.
The weld line browser can be accessed through the Mark Weld, Inspect, and Points tools as well as the Results Explorer.
- Use the search bar in the weld line browser dialog to
find and filter weld lines. Type a string and press
Enter or click
to execute a search. Clear the string or click x to return to the default view.
- Alter what information is displayed in the weld line browser by right-clicking on a column and choosing options from the dialog.
- Detected weld lines can be renamed using the right-click context menu. However, the naming assigned by HL-WC is preferred because it highlights weld-related data (number of components attached to the weld, their names, and the connection type).
