Each weld line in the model can be divided into two or more weld lines. There are two options that can be used to
divide the weld lines - Divide and Divide Unconnected.
Use the Mark Weld tool to detect, create, edit, and delete
weld lines.
Weld Line Browser
The weld line browser organizes the weld lines that have been detected in the model.
Detect Weld Lines
Detect the welds in components which are currently visible and organize them in the weld line browser.
Add Weld Lines Manually
You can add weld lines to the model manually. This gives you complete control on how the weld line is defined.
Weld Line Directions
Learn weld line direction conventions and how to rotate welds.
Divide Weld Lines
Each weld line in the model can be divided into two or more weld lines. There are two options that can be used to divide the weld lines - Divide and Divide Unconnected.
