Save Files
Save all of the data in your current session.
- From the Home tools, Files tool group, click the Save tool.
- From the menu bar, select to save the model under its current name.
- From the menu bar, select to save the model under a new file name and/or directory.
- Press Ctrl + S to save or Ctrl + Shift + S to save as.
