Bars Panel
Use the Bars panel to create, review, or update bar2 or bar3 elements.
Bar Elements
1D elements created in a space between two or three nodes of a model where beam properties are desired.
The nodes are related to each other based on the properties of the bar or beam element connecting them. Properties associated with bar elements include vector orientation, offset vectors that end at A and B, or at A, B, and C, and pin flags to tell it what degree of freedom should carry through the beam.
Bar elements are displayed as a line between two nodes with BAR2 or BAR3 written at the centroid of the element.
Bar2
Configuration 60 - 1D (1st order) elements with 2 nodes used to model axial, bending, and torsion behavior. Bar2 elements have a property reference, an orientation vector, offset vectors and ends A and B, and pin flags at ends A and B.
Bar3
Configuration 63 - 1D (2nd order) elements with 3 nodes used to model axial, bending, and torsion behavior. Bar3 elements have a property reference, an orientation vector, offset vectors and ends A and B, and pin flags at ends A and B.
Bar2 Subpanel
Option Action
node A / node B Select one node at each end of the bar.
orientation
Select how bars are oriented in 3D space.
Vector
Use the standard plane and vector selector to determine the orientation of the bar.
Select three points to define a plane whose normal serves as the vector using the N1 N2 N3 selectors.
Specify a global axes by selecting x axis, y axis, z axis.
Specify a desired vector by selecting vector.
Components
Determine the bar's orientation relative to how the bar element's coordinate system is defined.
Orientation in basic
Use the default system of the grid points that define the element.
Orientation in displacement
Applies only if the referenced grid points have a displacement system defined.
Specify the direction of the local y axis of the bar by entering the X, Y, and Z components.
Node
Select a node to specify the vector orientation using the direction node selector.
Plane
Make the vector parallel to a plane based on the global coordinate axes.
Select a combination of the global coordinate axes that describe the plane you wish the bar to be parallel to.
pin a / pin b
Specify the degrees of freedom which are not intended to transmit force.
Note: Terminology varies between different solvers. For example, what is referred to as "pins" in this panel is sometimes called "beam releases".
property= Select the collector whose properties the bar should share.
elem types= Select a type of elements to use when creating the bar.
offsets in basic / displacement / elemental
Select the bar's offset direction(s), which depend on how the bar element's coordinate system is defined.
offsets in basic
offsets in displacement
offsets in elemental
Offset in the directions defined by the bar element's own orientation system.
offset values Specify the ax, ay, az, bx, by, and bz values for the bar offsets. Because bar elements are modeled as 1D objects, these values represent the distance between the real-world edge of a bar and its center axis. For example, if the bar was cylindrical in shape, A and B would determine where the edge of the bar would attach to another element, but the offsets would represent the radius of the cylindrical bar and therefore would identify where the bar’s central axis lay in relation to the connection points.
Bar3 Subpanel
Option Action
node A Select a node at one end of the bar.
node B Select a node at the midpoint of the bar.
node C Select a node at the other end of the bar.
orientation
Vector
Components
Node
Plane
pin a / pin b
offsets in basic
Update Subpanel
Use the update subpanel to modify the values assigned to existing bar2 or bar3 elements.
Option Action
elems Select the bar elements that you want to update.
orientation
Vector
Components
Node
Plane
pin a / pin b
offsets in basic
Command Buttons
Button Action
update Update the bars with the changed information.
review Review the bar element, or create bar elements similar to existing bar elements.
When you review a bar element, the bar is drawn in the offset position with the local axis and other information displayed. In addition, the values of the offsets of the bar are displayed on the panel.
To create bar elements click review to select a bar element, then use the values that display in the data entry fields to create a new bar.
reject Revert the mostly recently performed action.
return Exit the panel.
