Midmesh Panel
Use the Midmesh Panel to automatically generate a mesh at the midplane location, directly from the input geometry (components, elements, solids or surfaces), without first creating a midsurface.
Create Subpanel
Use the Create subpanel to control the resulting midmesh output.
entity selector
Select the source used to create the midmesh.
Destination component
Select which component newly created midmeshes are placed in.
Ignore flat edges
Do not imprint flat edges from the input geometry onto the midmesh.
Figure 1. Option Off
Figure 2. Option On
Flatten connections
Aligns/flattens the midmesh at ribs/connections.
Figure 3. Option Off
Figure 4. Option On
Edit criteria
Set the minimum size and target element size settings in the criteria file to control the resulting midmesh via the Criteria File Editor.
Extraction size
The midmesh extraction size. By default, this is taken as the target element size from the criteria file. This can be set smaller than the target size, though that is not recommended unless there are problems extracting at the target size.
Minimum size
Minimum element size allowed in the finalized mesh. This in combination with the ‘suppress proximity edges factor’ and 'combine non-manifold edges factor’ can ensure that the output mesh is ready for rebuild with the same criteria.
Can only be modified in the Criteria File Editor.
Suppress proximity edges factor
The minimum size factor for removing edges within proximity. Edges closer than this factor times minimum size will be suppressed.
Figure 5. Option Off
Figure 6. Option On
Combine non-manifold edges factor
The minimum size factor for joining non-manifold edges. Non-manifold edges closer than this factor times minimum size will be combined.
Figure 7. Option Off
Figure 8. Option On
Defeature openings with width <
The maximum width for removal of small holes and openings.
Figure 9. Option Off
Figure 10. Option On
rebuild mesh...
Opens the Rebuild Mesh Panel.
thickness map...
Opens the Map Midmesh Thickness dialog.
comparison...
Opens the Comparison Tool dialog.
Edit Edge Subpanel
Use the Edit Edge subpanel to repair 1D topology edges.
create mid-edge
Create a new mid-edge, optionally using the input geometry as a guide:
Figure 11. Before
Figure 12. Without Guides
Figure 13. With Guides
split by two nodes
Create a new edge between two nodes.
Figure 14. Before
Figure 15. After
split by node-edge
Create a new edge between a node and an edge, using a shortest, tangential or mixed path.
Figure 16. Before
Figure 17. Shortest Path
Figure 18. Tangential Path
Figure 19. Mixed Path
delete edge
Delete an edge.
Figure 20. Before
Figure 21. After
t-edge align
Align/flatten a t-connection edge to a surface.
Figure 22. Before
Figure 23. After
by geom edge
Align mesh edges to input geometry lines and smooth the mesh:
Figure 24. Before Align
Figure 25. After Align
Imprint geometry edges onto the midmesh:
Figure 26. Imprint Before
Figure 27. Imprint After
replace node
Opens the Replace Panel.
edit element
Opens the Edit Element Panel.
edges
Opens the Edges Panel.
delete
Opens the Delete Panel.
align nodes
Opens the Node Edit panel, align node subpanel.
project
Opens the Project Panel.
rebuild mesh...
thickness map...
comparison...
Edit Face Subpanel
Use the Edit Face subpanel to correct issues with midmesh faces.
fill face
Create a mesh within a closed 1D topology loop, attempting to keep tangency. Optionally, the 1D loop can be deleted, keeping only free and non-manifold edges.
Figure 28. Before
Figure 29. After
repair face
Attempt to fix topological problems (holes/gaps/cracks, intersections, slivers, overlaps) in the mesh and remesh the face.
Figure 30. Before
Figure 31. After
detect intersections
Detect intersecting element clusters and holes/gaps/cracks, and create element sets for further handling.
Figure 32. Before
Figure 33. After
align face
Align a selection of elements to an input geometry surface:
Figure 34. Before
Figure 35. After
An optional offset can be specified to align the mesh at a given distance away from the surface:
Figure 36. Offset
Optional locking of boundary nodes of the selection will treat them as anchors:
Figure 37. Lock
replace node
edit element
delete
project
rebuild mesh...
thickness map...
comparison...
